All the Sydney Rolla Boyz Holla me
Ln106 Hilux Engine Conversion.. 3l to 1kzte
Hey guys! Not sure if anyone still looks at this thread... i have a 1991 2.8 diesel Hilux with mint running gear but the body is rusted up. I was was wondering what the possibility is of taking the engine and gearbox from my Hilux and putting it into a 1996 Toyota Hilux surf body. The main problem i think will be the fact that my Hilux has no electronics and the surf does... -
4
Converting my corolla into a Sportivo
i own an official TRD Supercharger that's OEM for your Corolla if you're interested as I'm selling it. It's bolt on, average 5 hours but if you take your time possibly take a day. If you want to stay naturally aspirated, then do the engine swap. If you're looking for forced induction, this an official TRD supercharger can be considered. -
16
Official TRD Supercharger for 1ZZ
parting out the TRD Supercharger. If anyone is interested please drop me a line. -
Ln167 crankshaft damage what are my opinions
Hello I'm looking for help with my 1998 toyota hilux ln167 3L diesel with the 5L motor as i started to notice a knocking noise after I did a 4wd trip and found out it was a the harmonic balancer as I was taking it off the harmonic balancer was really wore in the key way and the same on the shaft of the crankshaft, do I need a new crankshaft? Crankshaft https://photos.app.goo.gl/GHoXsXsdCJeDsNrz8 Harmonic balancer https://photos.app.goo.gl/9iUKALStsVjWZyzX7 -
iPhone intermittently connects to CarPlay or visa versa?!
So I have changed out multiple cables. I don’t believe it’s the phone but rather the cars electronics? I plug the usb into the port near handbrake middle console. sometimes Apple CarPlay comes up and others not . Phone is being charged so a connection is occurring electrically. ideas ? cheers -
Gents, I want to narrow down possible cause, as I'm not a pro... - I can lock/unlock all 4 doors with key. - I can LOCK all doors with fob, when unlocking with fob, driver's doors stays locked. I found the small plastic hatch on door panel which moves when you lock/unlock doors wont move properly when locking/unlocking. Is this likely to be a mechanical issue? Should I just put some grease on cords inside the doors? Or issue could be with locking actuator? Thanks for replies! Cheers. Martin -
2004 camry ventalation cables
hi need to out new bulbs in my base model ascent camry hvac controls box how do i remove the cables at the back of the box to get access to the bulb holders to change bulbs -
indicators /hazard /central locking lights stop working
can anyone help my indicators / hazard lights / central door locking lights just stop working . i was told it could be the flasher relay so ive changed it it worked for a day and now its gone again this time the hazard lights / central locking and only the right hand indicators works any suggestions by anyone -
5
Adding driving lights into a Toyota Hybrid (Kluger)
Hi, I have 2021 Toyota Kluger Hybrid. Did you have any problems mounting driving lights?? That is; did they effect the sensor (that is mounted within Toyota logos on front of car) Thanks Mark
