After I got the sports grill put on i didnt like the fact that you could see one of the horns through the grill.
I finally got off my butt this weekend and moved it. I ended up placing it with the second horn below the grill. All that needed to be done was to change the angle of the mounting arm so that the wires were not hitting the front bar.
http://www.toyotaownersclub.com/gallery/au/Dsc00711 <- new location
http://www.toyotaownersclub.com/gallery/au/Dsc00712 <- looking through grill
Thought some of you might like this, as I know it annoyed me.
Cheers :D
Danthuyer
Dude, I love you (in a striuctly none gay way, in a sort of fellow sportivo / just solved my ugly horn through sports grill issue sort of a way) I am SOOoooooooooooooo going to do this next weekend :)
Sorry mate took your idea which was a great idea by the way... :D. But I had to change it a bit. Where you have placed your relocated horn was ok. But I have another revision for you. Instead of placing the second horn where just behind the grille (which in an minior accident could cause more damage)., put the horns so they face away from from each other (back to back instead of cheek to cheek) it looks better and is not so tight and does not hit the front grille (when you re install it) as it did when I did it your way.
Posted (edited)
point noted and taken - i didnt even think of that <_< Well done peekay
Peekay 1
Danthuyer 0
you just had to go there didnt you :P
Out i go to change over now...hehe
Edited by Danthuyer
oh mad.... this is great... i noticed that when i was lookin at the car... as soon as i pick it up on friday ill go about changing the horns :P
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
