WTB: Coilovers/ lowered springs to suit ZZE corolla
Fuel Filter - Change or not
This is the conundrum: 200 series Landcruiser diesel. As the fuel filter get dirtier, in theory it is filtering more as it is becoming somewhat restrictive. As long as the fuel pressure remains the same on the other side, should you change the filter. I know of owners who change their fuel each time they change engine oil. This is not the same as an air filter which as it get dirty it restrict the air flow. Or do you simply change the filter because it's 'the right thing to do'? -
2013 cruiser gxl ute
The brake lights come on at times when the ignition is off ,I've changed the brake sensor above the pedal and also while driving at times I lose power -
I bought my 2006 ATX Aurion back in 2015/2016 with 160,000 KMs on the odometer. 8 years and 100,000+ KMs later, still going strong. I do a lot of preventative maintenance with regular engine oil changes. Transmission fluid has been changed and also the coolant. In that time period, I have replaced the water pump, alternator and both front and rear struts/shock absorbers. In hindsight, I have replaced brake pads much sooner than needed. Overall, future maintenance should not be expensive.- 1
Hi Reece, I've been trying to reply to this post, but for some reason the site wouldn't let me. On one of my morning walks, with my dogs, there is a Hi Lux tub sitting on the nature strip. I know nothing about it, except that I think the owner could well sell it, but hasn't. I will attach a photo for you, and if you are interested I will email you the address, if you PM me with it. Note that it is in Geelong, Victoria, maybe a good reason to visit. . Herb -
Fitting on the headlight bulb appears to be the usual twist to release and lock. Definitely do not try to brute force the removal because you will definitely break something like the headlight housing. Suggest that you use some WD-40 and have a real good look at the existing bulb using a mirror and a good light source. Then have a few wiggles attempts to loosen the existing bulb so it can then be removed. If this does not work, then time to be smart and not stubborn. Far better to pay a $15 fitting fee than the exorbitant cost to replace a damaged headlight assembly.- 1
help with clutch
High mileage camry
1981 Hiace ignition upgrade
That is about the standard price you'd expect nothing crazy, I paid pretty much the same for a 2008 model with 160k on the clock. As to the high km's and maintenance, 165,000km for a Toyota is nothing to sweat about and the maintenance/repairs are pretty cheap. If it's been treated well by the previous owners and you continue to look after it then it will easily last you another 5 years.
