The transmission shifts smoothly from 1st to 3rd then doesn't shift to 4th. A lack of maintenance is probably finally killing the car but does this mean the transmission is dying? Or can I still save the car?
Any advise would be appreciated.
I'm not sure if it's the overdrive. If I'm not mistaken, it's a 4 speed transmission? If it helps, normally the car is probably a little over 2k revs at 80kmh. Now at 80kmh, it is at over 3k revs.
does it have a overdrive button on the t bar? If the overdrive is off, there will be a "OD off" light on the dash
Can anyone recommend a mechanic in Brisbane? Thanks
      Remote start
    4. 9
    5. 9
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
