Can anyone advise me about getting a service manual, or at least, a wiring diagram for my 2002 Estima.
Engine fans not running, checked everything is OK except no trigger voltage to fan relays.
I would happily purchase a CD if I could find one.
Posted (edited)
Estimas are made in Japan for the residents of Japan. There are no English service manuals.
There are two options:
1) Put your name on the list here http://www.jpnz.co.n...uctdetails.html
and wait until they get 150 takers.
2) Download a "sorta" manual from here
http://toyota.downlo...03-04-05-06.htm
I chose the second option. The upside is that the wiring and general layout is pretty close to Estima from what I've seen. If you have a 2.4 4 cylinder you are better off than me. The manual covers the 2.4 and the Diesels (but not the V6). However it's generally good enough to get you through.
Be aware the the Estima ICE (in car entertainment) systems are nothing like what is in this manual. But that is another story.
Another useful resource for Estimas is here: http://www.teoc.ws/
Scroll down to " new Estima" at the bottom of the home page to reach Forums.
"New Estima " up the top gives gives good info on fuse locations.
EDIT: A quick look at the circuit suggests the load circuits to the fans are fused in engine bay fuse box (above the engine)
The relay coils are supplied positive via the "gauge fuse" I'd looking in the drivers footwell fuse box
http://www.teoc.ws/fuse-box-locations/#more-119
The negative of the coils are switched via the engine ECU which located behind the glove box in the the cabin on the extreme LHS.
Edited by robmac1
Thank you for your input, Robert. it seems tha a sensor at the bottom of the radiator, or somewhere near, had gone out.That problem has been sorted, along with some other stuff.
I have a 20Mhz. FM Expander for the ICE but will have to check out more Oz friendly ICE units, a fair way down the track.
Cheers, Davo
  • 7 years later...
