Dash twin camera with GPS & G-Sensor - offer ends 10pm 7.10.2012
Engine and radiator leakages
Hi Ind, Thanks for your suggestion. Do you know of any mechanic who does change the entire engine assembly and the radiator? Cheers, Lou -
4
2018 SL. Reversing camera display stopped being animated.
Apart from trying the same thing in a different gear and/or moving slowly as you turn the steering wheel each way I don't know what else to suggest. The battery being disconnected was what caused my issue. -
2019 Landcruiser 200 Map update Bricked System
Adam, reality is whilst it is handy to have an onboard GPS unit working, we have resorted to using Google Maps on the phone. It is accurate and always up to date. WAZE is also another App if you're into that. -
When the car runs/idles does it have a ticking noise coming from inside the engine? And also are you loosing coolant from the radiator? After you run it for a while does the temperature gauge in your dash go beyond the safe level? If you need to replace it the costs of the engine and radiator won't be much if you could get it out of a wrecking yard but the garage labor is gonna be costly. -
G'day, My Toyota Camry 2004 Altise has Engine and Radiator leakages as informed by my mechanic. When I start the car, it runs smoothly for about 10 minutes but then has to be stopped as I notice the yellow engine icon lit on the dash board. The car starts to shake a bit, at which point I stop it and let it cool down for about 10 minutes. Sometimes, it starts and runs for another 20 minutes before coming to a halt again. My mechanic suggests complete change of engine and the radiator. Any suggestions if replacing the old engine and the radiator would help me to keep the car? Any ideas of how much will all this cost? Any info on car mechanics that replace engine and radiators would be of great help. Cheers -
4
Just tried it. Didn't seem to work. Maybe I'm doing something wrong? -
4
Thanks. I'll try it and see what happens. I did since have to buy a new car battery as my old one went flat. Maybe the old battery getting old caused the problem? -
4
Hello, I had this happen to me when the battery connector worked itself loose and intermittently disconnected. I worked out the dynamic guidelines needed to be recalibrated after the battery disconnected. In my 2016 Camry I did this by turning the steering wheel full lock in one direction, then turning it full lock in the other direction. I can't remember 100% what gear I needed to be in, but I think I needed the engine to be running and either in Park or Drive. I did my calibration in my driveway so I don't think the car needed to be moving at all.- 1
4
Android auto
I've been tried 8 different units wireless Android Auto adapters, none of them are working. I'm very regret bought the RAV4 Crusier. -
250 series Kakadu flat tail gate model
Thanks for that news. Was there a lot of them ? And if so what models were there? Any Kakadu’s? That is progress anyway
