Hi shoppers,
I've got a second hand TRD sportivo suspension kit for sale. Suit Corolla 2001 - 2006 series MK9. ZZE series.
Never done any track racing or serious abuse to it. Used only under normal urban driving condition. I just wanted a lowered look for my car ;)
This is a great kit that lowers the car and gives it a more balance (front to rear) look. The car is flatter on corners making direction change faster. The car's dynamics changes completely when compared to stock suspension. You'll feel so very stable that at first the car feels like it is not moving (or absence of wobbling).
Condition:
50000KM usage, Still in very good condition apart from minor surface rust, scatches and dirt.
TRD Sportivo Suspension Full Set:-
Shock Absorber Set: 48030-ZE210
Front shock absorber: 941/429N
Rear shock absorber: 1060/908N
weight: 12.3kg
Coil Spring Set: 48130-ZE210
Front Coil Spring: K=40.0N/mm
Rear Coil Spring: K=39.5N/mm
weight: 9.7kg
Ride height: Approx. 35mm lowering for Sedan
*copied from TRD webpage (see the PDF file).
For images and a brief website specs:
https://www.dropbox....aj47/IiddSYxRcu
You've also got a Repco spring compressor set which I've used only once. You'll need it for a DIY installation. half price $35.
Goto my ebay ad to bid or buy it now for $375.
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=110961673220#ht_626wt_1139
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
