Carbon Fiber ZZE Front Lip Where???
LFT-OOF
That's the Levin one Steve.
No one makes a carbon fibre one, you'll have to go custom. I wouldn't imagine much change from a grand. Otherwise you can give it a go yourself, it's surprisingly easy to do a decent job (but hard to do a perfect job).
To be fair thoguh, I'veb only used fibreglass, not carbon fibre, principal is the same though. You can use fibreglass fabric, instead of CSM, and it'll give a similar look to carbon fibre. Stay away from epoxy and the costs can be pretty cheap.
Taking the mould of the lip will be the hard part as it needs to be pretty stiff. Make friends with a good glassing supply store, they can offer a lot of advice.
      Fuel filter change - start stops running
    2. 17
      Wobble at the front
    3. 7
      Brake issues
    4. 10
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    5. 25
      RADIO CODES "HELP"
    6. 17
      Wobble at the front
    7. 11
      rear wheel arch hole covers (3rd row seats removed)
      2013 Kluger grande Bluetooth music issues
      2010 MANUAL Prado with high speed acceleration hickup
    10. 1
