Kluger bluetooth setup
Lukejj
We recently bought a Kluger 2010. It's a great car and we're really happy with it.
When we bought it, the dealership setup the bluetooth with my phone, however, since my wife is driving it more often I'd like to setup hers.
The only problem is that the manual we have doesn't cover the procedure. Can any please give me some pointers on how to do it.
Our car is a 2010 Kluger KX-R
Thanks,
Luke
Thanks,
Luke
Hi
Check the Radio/cd Manual?
  • 3 years later...
On 23 February 2013 at 4:16 PM, Lukejj said:
Thanks,
Luke
Hi I had the same trouble info on bluetooth was not in the manual for my 2010 kluger altitude.
But try turning the radio off then push the tune-file knob. Then select others.
then select bluetooth, and it will give you the option to register a telephone or an audio device, select telephone.
then select register telephone and turn the Bluetooth on in your phone and pair it up, the pass code and everything will be on the screen.
Hope this helps
Pete
Edited by Pete 87
  • 3 years later...
I struggled and found this helpful video on youtube. It is made probably for Toyota Kluger 2009. Check it out as it may be helpful for some.
https://youtu.be/-xcWA1HwYqA
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
