How to improve stability?
Hi All, I'm wondering if I can learn from those more experienced here. I owned a Corolla accent sport sedan 2011 and the car kept swaying left and right while driving at 100kph. Now the swaying isn't really that bad but I have to keep adjusting the wheels even if it's a dead straight line.
I have aligned the wheels a couple times with Toyota service center and yet it still happens (bit better after alignment, then getting unstable soon after).
Does anyone have the same issue with me? If yes what sort of things that you do or modify to improve the stability of the ride?
Thanks in advanced.
lowering it won't solve the problem. Sounds like the steering rack is loose. New bushings should hopefully fix it, but I'm surprised it's done it since new. A wheel alignment won't help things as it won't be dynamically shifting left and right like worn bushings would (unless the steering rack is loose).
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
