AirCon/Centre Console?
sam.karim
Hi everyone..
I have a 2003 Toyota Camry Sportivo and my lights in the centre console have stopped working.
Im pretty sure its called the centre console, its basically the lights for turning on/off the air, the temperature dial and all that!
I've never really experimented with cars, so I'm not sure how to do this.. anyone know any tutorials? so i could check out if i would be able to do this or not? :D
Any help is much appreciated!
Thanks in Advance
This Video may be helpful.
The difference between the video and your sportivo is that you will need to remove the Frame around the Radio first. 2nd - remove/unscrew the stereo, then remove the aircon centre dash. (All trims are held on with Clips)
      Head Unit with Apple CarPlay
      Any RA 60 owners?
      Bluetooth stopped working
    6. 3
    7. 2
