Posted (edited)
Had some time to kill, so I got around to fitting the auto mirror and auto headlights module, took awhile but here's some pics.
I got the Toyota Yaris one, it's the same part number on eBay but cheaper. (no's PT370-02090)
Auto mirror features cool, the tint on rear window doesn't affect operation, and not having to touch to adjust is great, it just dims all the rear lights to a green tinge and not so bright.
Two mirrors, auto mirror slightly bigger.
Auto mirror has a LED downlight for the gearshift, if you've gone for different colors inside, probably better to get one without it, I've got the ultrabright whites in the mapreaders but a really bright amber for the door light so it blends in.
Fitted to the windscreen, tighten with a T20 torx.
Fit the wire cover to the headliner.
Run the wire along the headliner and down the A pillar.
Hooked up to the accessory line, I used cigarette lighter (grey wire) and chassis ground at bottom of kick panel).
Edited by Bry
My Presaras got this mirror already but it doesn't really make a difference my rear shield is 5% tint so dark I don need the mirrors lol it stops 95% of light coming in. But well done
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
