Lift Bolts
51EKA
It's been confirmed that the australian celicas do suffer from broken lift bolts like the american celicas. Recently two of ozcelica members had their lift bolt checked by toyota and both had broken bolts. But lift still worked on both cars.
Wondering if any of you guys have check your bolts?
the engines in the celica and sportivo are actually diff, if you look at the two cars side by side you will notice that they are physicaly diff, mostly around the intake manifold, so its not a surprise that an issue that effects one car does not effect another, also the celicas are made in JP? the sportivos are made in SA, mabey they got somthing right over there...
As quoted by toyota Australia and we believe everything they say right :angry::angry::angry::angry::angry: there are no build qualities out of south africa <_< <_< <_< <_<
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
