G'day, I'm new... well kinda!
1uz
Hey all, I'm chasing an ecu pin out and engine wiring harness diagram for a 1990 Celsior ecu number 89661-50102. any help would be greatly appreciated, cheers -
2009 Tub Replacement
Hello All, I need your help about a tub replacement for my 2009 hilux V6 SR5. My model has no flares and tubs are difficult to find. I have found a 2012 tub and I am just wondering if it will fit my 2009 model. I get conflicting information on the internet. Are 2005 to 2015 tubs the same ?? Are they interchangeable? Any advice would be greatly appreciated. Thank you. -
New here
Hello Nathan from New Zealand ! Welcome to the forum friend. -
11
04 Estima cruise control speed limited?
I recently purchased a 2004 MCR30. It can't be set much past 105-107, so set the cruise control at 105 or a little higher, then nudge ("resume" / "+") it up to 110. It'll get there after a few nudges. It won't go further. (It's a genuine 110 km/h though, matching my Tom Tom.) -
Transmission broke down on Toyota Estima 2002 and 2013
Hi All, it is very unfortunate for me that i got Toyota Estima 2002 and had issue with transmission, and then I bought another one (because i like this car model) and got the same issue as the previous one. the first one got 260Km and I bought it from 75Km. i changed the transmission oils quite frequently though, so I guess oil was not causing it (unless the mechanic did it wrong) and the second one I bought it 3 months ago and that was 95K imported (as usual). expecting this to be better but I was wrong. the car came with extended warranty with integrity, and they are not that helpful when dealing with replacing the transmission which only covers max $1000 and same thing with the seller as they said everything already been handed over to the warranty. so that is a bit of background, but this sad story just for me 🙂, however what I need from you guys, I want to get this fixed cheap and reliable (cheap=not overpriced) do you have any good mechanic that can replace it cheaply (well transmissions always not cheap, as long as it is reliable and not overpriced) in Perth (Western Australia)? another question is how can I get 95Km transmissions for old car like this (2013)? thanks to all, your help is much appreciated -
Not really a new member, just back to say hi. :)
Hi guys, I drive a 87 Corolla seca ae82. I wanna put new wheels 4x100 and coilovers on it. -
Toyota Corolla Allex Negative Terminal Connector
You'd better off going to a shop and buy a new connector... That one looks rooted. -
Hi, I have a 2004 Toyota Allex. This negative terminal has since been loose but I’m having issues finding it to replace it. Can anyone link the harness? I plan on changing the positive terminal too
