Does anyone have a little trouble changing from 1st to 2nd when the engine is cold. Once it is warmed up it is fine. Is this normal? (other gear changes are fine...only stiff between 1st and 2nd)
Yes , for the first 5000kms.
It is starting to loosen up now , but for the first couple of minutes from stone cold i still rev match the upshift from 1st to 2nd until the mt oil circulates and then it shifts fine.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
