Which fuel filter for '95 Camry 5SFE
antik
The type of fuel filter which is recommended for my car is the Ryco Z424. However there is a Ryco multifit fuel filter which is the Z441 which says it replaces the Z424 along with a few other filters. Apparently they're the same filter with different brackets but I'm not sure if it will work or not because I've never changed a fuel filter before.
Here are the 2 filters:
Z424 (recommended): http://www.allpartsautomotive.com.au/COBOL/PICS/Z424.JPG
Z441 (multifit): http://www.allpartsautomotive.com.au/COBOL/PICS/Z441.JPG
Will the multifit work?
  • 3 months later...
I'd have to agree, go with the recommended. From the links you posted it would appear the outlet sizes are different, the multifit is M14 and the Ryco is M12 so that would pose a problem on it's own. :g:
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    6. 4
      2013 camry for sale
      Rav4 smart key keyless entry
