Hey guys
Can someone give me some ideas for front brake upgrade for a Ke70. ......I would like to keep the same wheels so am looking for the the most powerful brake upgrade to suit.
Any ideas or suggestions greatly appreciated.
Cheers Dave
Why the need for the brake upgrade? Nothing really bolts on directly, the common method would be to convert to an AE86 front setup and then go down the same path as all the hachi guys do. From memory there are also some S13/RX7 conversion paths to go down, but it would be worthwhile determining how much you want to spend/modify based on your desired outcome. No point throwing thousands at converting to RX7 brakes etc when you're still keeping the 4K.
Hi Hiro
Already has 4age...te50 5 speed.....coilovers.........looking at hillclimb/club car so exploring my options.
This wont be the end of setting up the car......I'm wanting to finish what had been started to make it a useful little car.
Since you've already got coilovers that basically ties you down to either the AE86 upgrade path or something like a Hoppers Stoppers kit (would be worth giving HS a ring, tell them your setup and see if their kit will interface with it). Most other options would probably involve new struts/coilovers.
      Turboed Corolla Overbuilt?
    2. 3
    3. 3
    4. 0
    5. 6
    6. 18
    7. 5
      Tow bar
    9. 3
    10. 0
