A few Questions
I lowered my car using Kings super Lows, i have a couple of questions if someone would be able to answer them for me
1. Is the car of a legal height limit? Basically has anyone been pulled over by the police and had a height check done?
2. Do i need a camber bolt? In my searching i noticed that some of you on the forum have put a camber bolt onto your car
3. What life expectancy should i expect from the standard shocks because i didnt change them. I dont drive on sydney roads as much as i use to. I did have a faulty left shock that was replaced back in 03
Your help would be appreciated
1 - I believe the legal height requirement in NSW is 100mm. I could be worng though. You will find that most insurance companies want at least 100mm ground clearance and no more and an 30mm lowering from standard height.
2 - No, but it helps.
3 - Some people claim as little as 20,000km's with Kings and standrd shocks, however others have found 40 - 50 more realistic.
Nice answer!!! Gee now why didnt i think of that???? :angry::angry:
I know that camber is the angle at which the tyre sits and the bolt helps to adjust this - i was expecting more of an answer like it decreases tyre wear or improves handling even more or something along those lines
Having a +ve or -ve camber will increase tyre wear. Having a -ve camber will give give you a quicker response going into the corner.
Is a very cheap/good mod to help handeling but only thing is tyre wear will increase.
Changing the toe will also help but tyre wear :(
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
    9. 1
      Seat change
