Aurion ZR6 taking long self start
Alee.Riz
Hi Guys,
I am wondering if anyone here has encountered a similar issue. Recently got my car serviced by my regular mechanic. My car has done 150k (Aurion Sportivo 2007 ZR6). Service included changing oil (pentix), oil filter (ryco), fuel filter (ryco), cleaning spark plugs as they were in good condition, cleaning radiator coolant, replacing breaks and top on oil levels.
After the service I noticed that the car is taking a bit long self to start. Took it back to my mechanic an he advised that it might be the fuel filter therefore he put the old one back but still the same issue. Now he can't figure it out what may be causing the problem.
If anyone has experienced similar issue, please let me know.
Get the battery tested.
I had a similar issue with my Prodigy, turned out the battery was on its last legs, was at about 150k too.
I prefer Battery world in Beenleigh, the guys there look after you.
Once it was change started instantly.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
