Coilovers
HIROLA
Hey Guys,
Just wanted to get an idea from the guys who have coilovers, whether its worth it? What i want to know is how is the handling improved and what is the ride quality like?
Cheers
I bought my Tivo Drummond Motor Sport Coilovers and while they were
getting installed I also fitted it with TRD front and rear strutt braces.
My friend, with all honesty I have never driven anything like it.
It stiks to the road like baby **** to a blanket!
DMS are a little more dearer then most others, I'd never go back to normal setup
unless I sell her ;)
I hope this helps you with your search to the perfect ride!
Kindest regards..............
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
theres different sort of coilies u can look at, heres some that my friend and i researched on before i got my zero2..
cuscozero1 <--- aprox $2200?
cuscozero2 <--- aprox $2650
tein SS <-- aprox $1450
tein wagon <-- havent looked in..
d2 <--- aprox$1800?
DMS <--- $3k to 5k
Hot Bits <--- not sure
hey guys
i'm getting d2 into my car really soon. i just wanna know what set up i should have on it and also would it be worth while to install front and rear struct braces on the car too? or can it wait??
cheers guys
with D2's spring rates, u'll be needing kidney braces, too :lol:
:P
hey guys
cheers guys
buahaha smart ***** :P
Ok guys so we have answered the question of the coilovers, but what is the alternative? Are their any other shocks which are suitable for use with a lowered spring other the Koni's?
bilstein and eibach :)
:P
hey guys
cheers guys
kyb
What about monroe shocks are they any good with King Low Springs?
It all depends on how you drive, if you like maximum performance I
recomened coilovers.
Depending on which ones you get most of them have alot of adjustment,
so you can adjust to suit your driving.
With 40 mm DMS you have 30 different adjustments, but as I posted earlier
they are $3000 without instalation all depends on your budget.
If I were you I'd save up for coilovers, you won't regret it!
But don't forget, you also need a good set of rubber to get maximum performance
mines riding on 225/40/18 Pirreli P7's.
Kind regards.............
Edited by BlAcK JeT
I went down this road before, but ultimetly I decided to get get a regular spring and and adjustable shock combo, with front and rear sway bars and front strut brace. I imagine it wont handle as good as a set of coilovers, but i'm sure its not that far off especially for street driving.
Basically the only advantage that I saw was the fact you could adjust the ride height, which I probably would leave at the same ride at maybe 35mm low.
But you never know, maybe coilovers will suit you. I mean I was told not to get 18's cuz of ride quality, but I still got 18 inch wheels with 35 profile rubber and I think its a pretty comfy ride.
Are you talking about Koni Adjustables shocks? Or are you using something else?
hey guys
cheers guys
what's wrong with d2???
i don't get it
hey guys
cheers guys
i don't get it
He means u'll feel every bump in the road and some more....the car will be very stiff and bumpy on the street but probably perfect for the track where the road is perfectly smooth....
If you've driven on real bad quality road where ur car bumps up and down..d2 will feel like that on normal roads and probably worse...
hey guys
cheers guys
i don't get it
they come in very high spring rates. they even have a "track" rate u can specify. if i'm not mistaken, it's like more than 10kg/mm for the fronts.
