Hi, I have a 2001 Camry with a 5sfe 4 cylinder with LPG.  At idle. It's a little rough. Put it in drive and same. When parked a a little rev it sounds ok. Just bought so I think it's been sitting a little while with no use. What do you suggest could be an issue?
It could be a gas injector or a changeover issue.
You will be best served by taking it to an LPG specialist for a check over. LPG is not something you want to mess around with yourself, professionals even manage to blow themselves up on occasion.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
