Air Conditioner stops when 30deg or higher
Teggets
My 2006 HiLux A/C works great when driving without the caravan but when pulling the caravan and the air  temperature is around 30 or higher the ac will not work, I turn the ac off for a while, then turn on again and it will work again until I start to climb even the smallest hill.  Have had gas topped up, ac checked and working ok.  Frustrating, need some advice.  Told to check the relay switch but no-one knows where it is.
If the A/C system is working fine normally, there could be an issue of the condenser heat soaking. Do you have any non-factory fitted to the front of the vehicle? Bullbar, lamps, intercooler, etc?
Have a ARB full size bullbar fitted plus 2 driving lights.  Could it be the relay switch? As has been suggested by mechanic.  The bullbar and lights have been on the vehicle for sometime, we previously pulled a camper trailer and no problems with the AC
Edited by Teggets
add more text
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
