Hi i have a 2013 hilux diesel SR 76000km fuel warning light is on filter has been replaced no water etc evident but light still remains on car is performing fine any idea's ? Thanks in advance
Hi mate thanks just got back in from the shed had a really good read of the manual and the ECU holds the filter failure in memory so light stays on to rectify that you disconnect the sensor while vehicle is turned off then turn key on and reconnect sensor between 3 and 60 seconds did that and all is OK. Thanks anyway
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
