5SFE clutch alignment mandrel sizes?
Jim.
I intend to remove the gearbox, clutch and flywheel in my camry 5SFE engine, in order to replace the rear main seal.
I would like to find the dimensions of the alignment mandrel to re-fit the clutch in order to machine one up before commencing the job.
Does anyone reading know these dimensions? Or can you direct me to a site which list them please?
Jim.
I used to have these sizes, but I seem to have thrown the piece of paper away.
I just bought a universal kit off eBay; however, there was no clutch disc anvil the same size. I solved that by wrapping a heap of layers of tape around it. Worked a treat.
Or maybe hit up a local clutch shop and see if they have any of the free plastic aligners you get in a clutch kit these days, can't imagine they'd have much of a need for them
      1kzte throttle body
      Aftermarket parking sensor
    5. 4
      Head Unit with Apple CarPlay
    6. 8
    10. 1
      1kzte throttle body
