exessive wear on outer side of tire?
Joar Gruneau
Hi
I recently noticed  I have exessive tyre wear on the outside of both the front  and rear tire on the right side. I also noticed that my tie end rods constantly have very different angles on the right and left side. I have added pictures of the tie end rods and a picture of the worn front right tire. I go camping a lot with a truck camper so which weighs about 500 kg. The wear is on both the front and rear tire on the right side which puzzles me. Could this be the cause of faulty rear suspension (the leaf springs are slightly more compressed on the right side) or is a camber angle or toe in problem?
I do regularly rotate the tires so it is possible all of the wear comes form one wheel but the rear right tire is showing nylon threads now and I think I would have noticed that last time I rotated (the rear tire has the same wear pattern as the front). It would be much appreciated if someone could give me some pointer, what might be wrong so I could know what to start looking at.
Best Regards
Joar
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
