Service and warrenty from Toyota
Seiko Obsession
Hi guys how are you?
I just got 2012 Camry with 103K on the clock from dealer.
My question is if I service my car at local registered mechanic does it still qualify  warrenty for Hybrid components?
Do I need to pay some particular attention when it comes to servicing?
 I believe that engine has a chain,when is recommended mileage for replacement?
Best regards,thanks for help.
Edited by Seiko Obsession
If you look in the front of the Service and Warranty booklet, it will have servicing intervals. The chain should not require replacement, the tensioner may.
If you don't have the manual, it can be found here: https://toyotamanuals.com.au/
Generally, as long as genuine Toyota parts are used, warranty will be retained. Factory warranty(non-extended) only applies for the first 3 years of ownership.
Thanks for info,I thought Hybrid components are 8 years or 160K or is it just a battery?
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
