2007 Aurion ATx alarm getting on
Hi Deepak and welcome to the forum.
I suspect you are handy and plan to do some trouble shooting yourself or perhaps get a friend to assist.
I'm not sure about headlights flashing. Is this what a 40 series is supposed to do when the alarm is triggered ? Maybe you mean the blinkers ?
The alarm thinks the car has been broken into and setting it off. The alarm protects all 4 doors, the boot and the bonnet. ( I think bonnet too)
You need to check the door switches, boot switch and if it has a bonnet switch check this too.
You could have an open circuit switch and when you press the "lock" on your key fob the system thinks the car has been broken into and sounds the alarm.
The random nature of the alarm triggering suggests that the alarm isn't satisfied that the doors/boot/bonnet are not secure.
Hope this helps.
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
    9. 1
      Seat change
