With the warmer weather I am using the Climate control a bit more.
I find it it very strange compared  to my past vehicles
Normally a low temp setting and Auto engages the air-conditioner
But I also have to select the ac button as well or I just get hot air blowing at a fast rate
Is everyone else's like this ?
You should only require to press the A/C button once, and once it has been lit up, the air conditioner will always switch on whenever you flick the fan speed lever up (to start the air flow).
When you press the OFF button it will switch the fan and air conditioning off.
The next time you flick the fan speed lever up, the air conditioner and fan will both automatically turn on.
This is how it works on my C-HR Koba.
Regards
Julian.
Not how functioned in my previous vehicles - aircon would light up when set to lower temp when under Auto
If I have to select Aircon and have lit - The light indicates its running all the time right - even when you pump heater up to max - aircon is still on
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
