Kluger Sat Nav DVD Map File
Chhris
Hi. My battery ran flat and as I dont have the original map dvd I was wondering if someone would be kind enough to send me a copy of theirs by email so I can load up the software? Currently my whole central unit is unusable : (  Toyota have asked for $150 minimum. I know its a five minute job for them. I cant find the file anywhere online. Hopefully someone can point me in the right direction. My model is Kluger Grande 2008 and the sat nav was running v15 of the software. I think any pre 2012 Kluger dvd file will work though. Thanks, Chris
Hi Kombi.  I've had a good hunt on there but a lot of the links seem to go nowhere.  I'm not that much of a techie.  I don't suppose anyone has a dropbox link or could e-mail me to to Gdrive or something similar?  Just frustrating toyota are wanting 150+ to simply place a DVD in my DVD player : (
  • 1 year later...
That version V22 "short version" from that URL willn't work unless you load the original Toyota disk first, then you can load the V22 disk.
I'm running V22 currently.
  • 2 years later...
  • 4 months later...
On 4/3/2022 at 5:29 PM, Adrians said:
Hi im looking for a map disc for 08 kluger does anyone know where I can get one
Follow this link for the last release of the disc map
https://au.lexusownersclub.com/forums/topic/14772-gps-v25-probably-v22-2019-for-aunz-dvd-based-vehicles-not-sd-card/
It's 5 years old but better than nothing if
  • your DVD satnav headunit still works
  • you have a DVD burner to write a 4.7GB disc
  • delete POISR008.IDX and POISR009.IDX - those are the NZ files, unless you planning to ship the Kluger to NZ so you can fit the file onto the disc
  • write at the slowest speed possible
