The rear latch on the driver's side sliding door is stuck in the locked position with the door open and so, the door will not shut properly. I have tried unlocking it with the remote fob-key (other door locks operate) and moving it manually with no luck. The plastic cover on the latch mechanism has come off and i have removed as much of the remaining plastic as i can and checked the fuses just in case. Need to get this fixed ASAP so the car can get a roadworthy inspection- rego due 3 days ago! Thanks in advance for any help.
  • 11 months later...
I have the exact same problem on passenger side but no luck fixing it either.  Just hoping there might be a chance of a solution now having been about a year since this was originally posted.  It's happened previously but we were always able to set the latch back to unlocked position by using a finger of screwdriver to flick it back.  Now it won't do it and not sure if it's the plastic that's jamming it.  It doesn't seem to be.  Is there a way to reset it?
Just hoping there's a simpler solution than replacing the part.
  • 2 years later...
Have the same problem! How did you end up fixing it?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
