Fitting a pre fuel filter
Thanks, looks like manufacturer can only replace. I've reached out to my Toyota dealer (where I purchased) directly. -
Try a search for compliance plate replacement. Herb -
2003 ln167 hilux 5le engine oil leak
Oil leaking from above timing cover/ crank seal, behind alternator, there is a lot of oil so it's hard to tell where it's coming from, head gasket is clean oil starts from underneath exhaust manifold, any help would be much appreciated, cheers -
Hi all, I've got a 2014 Kluger - just going through pink slip check recently and they mentioned the compliance plate was missing. He asked if the car had been in an accident and it was about 5years ago now. He said I'm screwed if I let it lapse rego and/or attempt selling it. How does one get a replacement compliance plate/sticker? Thanks in advance -
Steering wheels to fit 2005 Hilux Single Cab 2wd Ute
I was just wondering if anyone could please tell me if I can fit a sports or other slightly smaller diameter steering wheel on my 2005 Hilux single cab Workmate Ute (2.7l 2wd). I find the factory wheel is too big and I have been having trouble finding a sports wheel that will fit my ute. -
7
Android auto
For a an actual solution for this issue for anyone trying to find out how to get wireless android auto in their newer RAV4 - carlinkit 4.0 specifically works perfectly. I tried carlinkit 5.0 and the Motorolla MA1 and neither worked. But the 4.0 routes android auto through as apple carplay which the car likes more. -
Squeaking rear door
2017 VX with door mounted spare. I have been plagued with an annoying squeaking rear door for over 2 years. today I removed the body section of the door latch mount and turned it 180 deg. and presto, the squeak has gone🤷🏼♂️ This allowed the loop part of the catch to move a couple of mm forward and was enough to hold the door closed more firmly.- 1
New Member
Great car as an urban runabout. Still sad that our Yaris YRS hatchback got written off a few years ago. Nice power to weight ratio and so easy to park in tight/small parking spots. -
New Member
Hi All I'm Connor and I drive a 2008 Toyota Yaris Yrs, I bought the car yesterday, the previous owner had it since brand new and it has 75,000 kms- 1
