2007 v6 4.0
joshgreen
When was the last time you shouted it a new set of plugs ? NGK Spark Plugs LFR6C-11
Whilst changing them out disconnect the battery, letting the ecu to reset,
See if it clears the codes afterwards
Edited by CONROD
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
