Is it possible to remove the polycarbonate lens from the tailights (03 sportivo)? TIA
Sent from my iPhone using Tapatalk
Are you referring to the complete lense cover itself to remove it from the tail light? I mean it should be, they should be not much different from headlights which plenty of people have pulled apart to paint and modify before, someone correct me if I'm wrong though.
Yeah mate, the clear (or yellow as mine are) polycarbonate outer lenses.
The black paint inside is starting to bubble and crack, it’s due for a freshen up
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
