Hi all .. can someone please tell me how to properly fill the radiator coolant on a 2007 hilux which has not got a radiator cap .. thanks in advance
Fill the header tank  if you have or can borrow a pressure pump makes it easier fits on to the header tank  ,If not remove the screw on top of the tank bleeder get a small funnel and fill threw it takes a while .Start your motor letting it idle keeping an eye on the level top up as requires keep feeling the top hose to indicate eng temp once temp is up top tank is full  . check when cool squeezing the top hose youll hear coolant check header tank level top up as required
    2. 1
      Tyre Sale Specials
    3. 0
      overheated engine
    4. 1
    5. 62
    6. 1
    7. 1
    8. 1
      Tyre Sale Specials
    9. 10
      Android auto
    10. 0
