Hi all ... got a 2007 hilux which had a water leak at the turbo inlet pipe ... had the turbo removed and  the mechanic found that the pipe had a small crack in it .. replaced pipe , the leak has stopped now the puffs out white smoke out the exhaust and its using coolant ... any ideas
  • 4 months later...
Late, sorry,perhaps it is the egr cooler on the left side of the motor
is it white smoke or is it moisture? white smoke would indicate oil burning, tends to happen if there's an oil leak in the turbo such as the turbo seal failing.
    2. 1
      Tyre Sale Specials
    3. 0
      overheated engine
    4. 1
    5. 62
    6. 1
    7. 1
    8. 1
      Tyre Sale Specials
    9. 10
      Android auto
    10. 0
