I have a 1998 workmate dual cab with a busted odometer. The instrument cluster only has a speedometer but no tachometer. I was wandering if I got a cluster with a tachometer would the cable be sitting there waiting to be hooked up?
It is possible there might be a hook up for the new cluster. Are you able to check off the donor vehicle ?
If not, then take a look at your wiring harness and see if there is a plug that looks like it will fit. They are usually plug specific so you can't connect the wrong one.
Let us know how you go.
Pics would also be great to illustrate this so others can benefit.
Cheers Mate :thumbsup:
