Posted (edited)
Hi guys.
This only just happened.
When key fob battery ran out, I unlocked the drivers door with the key only and the Alarm went off, and wouldn't stop even if I put the key in the ignition.
Is this what it commenly does, because my Camry key fob doesn't work at all and can lock and unlock the Camry without the alarm going off.
Any help would be appreciated.
Edited by awatea
What model/year do you have? No such thing as an AE107 in Aus
Sent from my SM-G970F using Tapatalk
Apologies It's a 2001 AE112R.
  • 2 years later...
Extract from Toyota Corolla AE112 Remote Central Locking and Alarm manual.
Manual Override
1. Unlock the driver door using the ignition key (horn will sound)
2. Using the ignition key quickly turn the ignition switch from the "ACC" to "ON" position 10 times.
3. Leave the ignition at "OFF" position after the tenth turn and wait for the horn to stop sounding.
If not, repeat again.
Hope that helps
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
