RAV4 newbie
garthkh
Welcome to the Forum. I expect that you would have the service history. If it has only been serviced every 12 months and you are planning upon keeping the vehicle long term then I would recommend oil changes every 6 months using a quality full synthetic engine oil.
Thanks.  Yes, That's the oil was intending to use. I have been using a half synthetic oil in the Corolla (as advised by the S'Cheap guys) that my grandson is taking over. I am in my late 70's now and I hope I don't have to buy another.
Look after both yourself and the RAV4 with plenty of regular and preventative maintenance.
Do a good enough effort and your grandson will be taking over this one as well when you move on to an autonomous driving capable vehicle.
Just have to stick around long enough to make that happen. It is all part of my future retirement plans.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
