Hi,I have 2005 Prado ,when in cruise control going up hill changes down as normal,down the other side or on the flat would travel at least one km.before changing back into top gear, any ideas.😚
When was the last time that you changed the transmission and differential fluids?
No idea,only had vehicle couple of months,you think that may fix the problem.
ounds like you bought the vehicle without a known service history.
No guarantee but a change of fluids using a quality brand with the recommended viscosity will most likely result in an improvement in the gear shifting.
https://www.penriteoil.com.au/forums/topic/12/Manual Transmission Diff Gear Oils/thread/738/Recommended Gearbox and Transfer Case Oil/post/1633
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
