Good day all , what other manufacturers wheels fit on camry? Has anyone experimented with this
Just like how Toyota doesn't use just one PCD across their range, same goes for other manufacturers.  Lots of 5x114.3 (for the widebody Camrys) options out there, you'll need to work out offset ranges though as it is one of the most common PCDs around so there will be all sorts that will have the right pattern but foul on guards/suspension etc.
      Tow bar
    2. 3
    3. 0
    4. 3
    5. 3
    6. 3
    7. 1
      Snapping wheel and axle studs
    9. 2
