Lost compression in cylinders 2 & 4 at the same time 2 is 20 psi and 4 is 30 psi. Cylinders 1 220 and 3 185. What could corser those to cylinders to drop compression and the same time.
I am thinking that the most likely underlying cause is a head gasket failure.
From my previous research, common causes of head gasket failure include using incorrect coolant which can damage/deteriorate the head gasket material and increased oil pressure due to overfilling the engine oil level. Another common cause is the engine overheating leading to the head gasket failure.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
