My 1995 Hilux LN86 started to vibrate when in idle at around 800rpm so I replaced all three mounts and the vibration is now worse, but as the revs increase above 1000rpm, whether in neutral or in gear, the vibration stops.
Your ideas to help me fix this issue will be greatly appreciated.
Thanks in advance.
take its manual ,whats it like with clutch in ?,be checking  flywheel , front balancer /pulley maybe an add on ,alt ,power steer anything that maybe out of whak or worn
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
