2017 Rav4 GX model - aircon button pushed into dash
boltaSTO
Greets to all . . .
As the subject suggests, I have a not-unknown situation where the aircon control button has been pushed right into the dash (see photo). Can anyone point me in the direction of instructions / video that can help me sort this s&^t out??
Hi there. It's pretty easy actually as modern interior componentry is usually a pop off style fixture with some screws.
Follow this video for disassembly stages. When you pull the head unit you will be able to access the climate control panel. You can then reach in and pop the control dial back into it's holder or if you want to, remove the control panel fully if you feel like applying some epoxy glue to reinforce the dial into position so it can't pop out again. Just a few small dollops around the inner circumference will do.
Cheers :thumbsup:
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    6. 4
      2013 camry for sale
      Rav4 smart key keyless entry
