KZN-165r to LN167 CAB SWAP?
OBD port lock for 300 series
Latest news suggest that car thieves are now using the OBD port to steal 300 series. Has anyone found a decent OBD port lock that works with the embedded OBD port in 300 series? -
Hey all! Recently upgraded from a 2009 Kluger Grande to a 2017 Kluger GXL... the 2009 was decked out with a round chrome nudge bar and all, making it easy to mount a UHF antenna up front! But, this newer model I have gone with the OEM Toyota nudge bar that I really like the sleeker look of, but it does not give me anywhere to mount a UHF antenna, and even more so, I cannot seem to find any bonnet hinge mounts for this year model available online! Not really wanting to go with any thoughts or suggestions greatly appreciated! Cheers! -
Tyre tread damage
Hi, My take is that your alignment is way off, despite what the tyre guy says. Find another shop, or go to a Toyota dealer. I had this happen, years ago, with my little Honda Scamp. Tyre guy set the toe to his "standard" 3 deg toe in. The car was a front wheel drive, spec was toe out 3deg, and yes, the tyres wore very quickyl. Herb -
Prado veggie oil
Correction: The power for the pump comes from the engine ignition 12v distribution in the engine bay fuse box. I will take a photo of it tomorrow and post it here in case anyone else wants to use +12V with Ign ON. Tony -
Tyre tread damage
Hey legends, I need some help here. My tyres gets wore out really quickly for some reason. Fitted 2 new tyres for the front Augest last year and was told today its gone (driven less than 4000km). The rear tyres are even worse. Ever since I got a wheel alignment done last year, the car seems to wobble left and right for 0.5/1 sec every time I drive passed small uneven surface on the road (rear wheels). Went back to the tyre shop and the guy double checked again. He said everything was fine. If it happens again after a week also, I might need to see my mechanic, as it could be a suspension issues. Anyone experienced similar problems? Any help would be appreciated . Thanks! (The photos are both front tyres after less than 4000km of normal driving) -
2009 Kluger white smoke
Yeah it's whit/blue, definitely from the oil in the plenum making its way down -
2005 Camry AC controller Lights not working
Hi Guys, I needed help regarding my 2005 camry sportivo 2.4 liter. It has the manual type ac controls and I am having trouble trying to get the back lights working. I was able to pry open the controller but it does not come all the way out and has what looks like hot and cold damper shafts attached to it at the back. So I pryed open the front cover of it to gain access to the globes. They don't seem damaged but won't turn on. -
6
2010 Hilux SR5 - occasionally not starting
Happy to help mate. Glad you got it sorted- 1
- electrical
- hilux 4x4
(and 1 more)
Tagged with:
In my knowledge base, white smoke means that water ( coolant) is getting in there. Oil issues usually create blueish smoke. Herb -
