Atara R Paddle shift conversion
2e4
Hi all,
I have an 2012 Camry Atara R, which does not have paddle shift, and have acquired a later model exactly the same steering wheel with shifters. And want to install this, has anyone got this to work, Changing the wheel over is not a problem, and with luck the wiring might be in situ making it a straight swap, plug and play. Anyone attempted this if so would appreciate your advice as to wiring etc.
Many thanks
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
