Hey guys, I've been looking to replace my head unit with one that has Android Auto/Car Play but haven't had luck finding any that fit. Any one know which head units are compatible with a 2010 Toyota Corolla Ascent Hatch Auto? I've attached a photo of my center console for reference.
Current head unit model is PZQ60-12020 if it helps.
if they don't fit search for a double din kit for ur model, the head unit u want & adaptor cables for toyota - headunit
Hi Ton, The head unit is a real personal thing it will always come down to what you can afford and what your wanting from it. I would check out good audio sound stores like Monster etc. They usually have a good range of units and all the cabling required and also can fit the unit for you. Buying online is one way but not one I would choose because you can not physically look at it ask questions etc much easier going in person to somewhere, even Supercheap or Autobarn are a good starting place.
Let us know what you end up doing
KAA
  • 4 months later...
Posted (edited)
G’day TGA, hope you got this sorted, just about any 2 din would fit.
I’m putting a pioneer one in but I’d like to know how to pull the trims apart to fit it 🤨
Every video shows the sedan with a different gearshift with short trims to remove but those 2 lower side ones are 1 piece on the hatch and I’m struggling. Do I need to remove console box to start removing those side piece.
Any help
cheers Sparky
Edited by Sparky600
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
