brake noise after new tyres
cranswick
Hi l just had four new tyres put on my 2003 camry today,  since then whenever l put my brakes on and the car comes to a complete stop it makes a grinding noise, l spoke to the guy who put the tyres on and he said its caused by the lubticant and its normal and will go away in a few days, do they put lubricant in when they change tyres, l am worried they might have damged something and just said its caused by lubricant to get rid of meshould l take my car to my mechanic to get checked
I highly suspect that they have over-tightened the wheel nuts. This will distorted the "hat" of the rotor resulting in the grinding noise.
https://21cylinders.com/toyota-camry-lug-nut-torque/
76 ft.lb = 103 Newton Meters
Definitely get the tyre shop to check/adjust the torque of the wheel nuts.
Bloody Lubricate, pull the other one. Get someone to crack all the wheel nuts, (evenly) and tighten back up by hand. They probably rattled them tight.
BA Falcons suffered warped rotors as a result of overtightening, then again make sure they are actually tightened
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
