I've got a first generation Kluger. Today, three things all packed up together.
1)  The indicators stopped working (although hazard lights still work)
2)  The electric windows stopped working
3) The headlights did not turn off as usual when I opened the door (I had to manually turn the headlights off on the stalk)
Has this ever happened to anybody else?
Any idea what's gone wrong?
Thanks for any info
John
Hard to diagnose electrical gremlins, but the first thing I'd do is run a diagnostic scan and see what pops up. You should see a fault code of some kind. It may point to what could be causing this issue.
If you don't have a scanner, i strongly suggest you buy one. I think we all should have one seeing we live in the digital age where almost everything is driven by computers.
Cheers,
Tony :thumbsup:
Thanks Tony for your reply.
By a weird coincidence, I was only thinking last week I should get a scanner.
Do you, or anybody else suggest a good brand
Thanks John?
It's difficult to recommend any one specific scan tool because there are so many on the market now it's become crazy.
I purchased an Autel  Maxysis MS906BT a while back and it's an amazing tool, but very expensive. You won't need anything like that unless you plan to do a lot of work yourself.
A decent scanner would probably be around $200 - $300 for what you need. Autel have many models to choose from and to suit your budget.
Take a look online and see what takes your fancy.
Thank you Tony for your advice. Cheers John
      Tow bar
    2. 3
    4. 3
    5. 3
    6. 3
      Snapping wheel and axle studs
    9. 2
      Missing compliance plate post accident repair - 5+ years ago
