Got a stock standard all round 2004 Camry with 205/60/15 steelies.
I've been offered a set of 4 Wheels / tyres from my neighbour (from a Subaru Outback), they are the same 5 x 114.3  stud pattern.  They have 235/45/17 alloys.
Apart from the speedo being out is there anything that would cause issues or would need changing for this, or are they a simple swap?
Safety would be the first thing that comes to mind. Just check they are compatible with your vehicle.
Check mating surfaces, offsets and wheel nut type.
If in doubt, you could just swap them for an original set of Toyota alloys.
      Tow bar
    2. 3
    3. 0
    4. 3
    5. 3
    6. 3
    7. 1
      Snapping wheel and axle studs
    9. 2
