Hi Lee-Anne, From what i have read The P0093 code is triggered once the vehicle’s powertrain control module (PCM) detects the possibility of a large fuel leak on the high-pressure side. The code is logged once the PCM perceives a significant drop in fuel pressure within the fuel system’s high pressure rail as reported by the fuel rail pressure sensor.
There are quite a few videos on You-Tube about the issue but it is not always for the RAV 4 so worth a look to see if one is for your model. I would be very careful if you intend to drive it as it can go into limp mode at any time.
I am sure if any have more information on it they will let you know
KAA
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
